air conditioner making noise
165,000 MILES • V6 • FWD • AUTOMATIC
SYLVER
  • 21 POSTS
I changed the alternator in my car. To be able to take the alternator out i had to remove the air conditioner compressor. Now , every time i turn on the air conditioner there is noise being made around the compressor and drive belt. The noise is only made when the air conditioner is turned on other than that everything seems fine. I want to know what is causing the noise and where should i check to fix the problem?.
Jul 5, 2016 at 12:06 PM
SYLVER
  • 21 POSTS
I also removed the idler pulley.
Jul 5, 2016 at 2:42 PM
KHLOW2008
  • 41,812 POSTS
Check the belt adjustment. Most probably the tension is insufficient.
Jul 5, 2016 at 3:54 PM
