A/C light will not turn on
145,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
SHWANA77
I have checked all fuses and relays and they are fine. What do I do now?
Mar 8, 2020 at 12:34 AM
We need to start with checking for codes. The A/C light not turning on is normally a relay or power feed issue. However, if the relays and fuses are okay then more than likely we have a circuit issue or control module issue. This would lead to us having a code in the system that will point us in the correct direction. At this point we will need to run through the test it lays out.
if there are no codes then we will need to start testing for power at the module which will be much more complicated so hopefully we have some codes.
Let me know and we can go from there. Thanks.
Mar 8, 2020 at 12:52 AM
  • 55,658 POSTS
On some of these the AC will not turn on if the charge is low. please use this video to check to see if that is your problem:
https://youtu.be/uZrQCGwXfek
Please let us know what you find.
Mar 9, 2020 at 7:42 AM
