cold air on passenger side?
92,000 MILES
SUPPUSH
  • 17 POSTS
The air conditioner is blowing ice cold air on passenger side, but warm air on the drivers side. if i set it to vent ( no air conditioner or heat) the cold air warms to outside air temperature on the passenger side, but the drivers side gets hotter, both of the heater core lines are red hot, i am thinking the thermostat must be leaking through, but a quick google search is talking about actuators and other things, i had 38 psi on the low side of the compressor so i believe it is charged correctly.
Jun 20, 2016 at 10:14 AM
  • 55,709 POSTS
hello, sorry for the slow response,
The air conditioner is charged correctly because you are getting cold air on one side, here is an guide on which actuator does what.
Let me know how it goes
Best, Ken
Mar 22, 2021 at 4:23 AM
SUPPUSH
  • 17 POSTS
hello ken,
thanks for getting back to me. I believe i fixed the issue i added another pound of 134a, and they are all blowing cold... very strange as the low side was not dropping below 32 degrees. i do residential hvac for a living. Im assuming that possibly only half the evaporator was getting cold, as ive seen with sticking txv valves etc... but the refrigerant seems to have fixed it. my wifes grandfather is getting cool air again :) if he comes back in a week ill have to try to figure out where the blend doors are.
thanks again,
Martin
  • 55,709 POSTS
Hey Martin
I had not heard of half the evaporate not getting cold but there is a first time for everything, good to hear you got it fixed. Please let us know what it goes this weekend, thanks for using 2CarPros
Best, Ken
