A/C intermittent on hot days
140,000 MILES • 4 CYL • FWD • AUTOMATIC
TINNOV
Recently, my car has been having intermittent A/C problems. Whenever the outside temperature is over about eight five degrees F, the compressor will turn off. I will be driving along, everything is fine, then the vent air starts to warm and I can smell the condensation evaporating off the coils. It will stay off for in excess of ten minutes. I have observed it not working for over an hour. Parking, shutting down, removing key, and restarting has no effect.
I took it to the dealer and they evacuated it, refilled it, "replaced a relay", and charged me $400.00. Had no effect whatsoever.
I took it back today and they said I needed a new condenser coil, evaporator coil, and compressor clutch. I sense that they have no clue what is going on.
Suggestions?
Thanks in advance!
P.S. - I do not have much experience with car repair, but do electronics work. I know my way around a circuit board and understand general engineering/mechanical principles.
Jul 10, 2017 at 8:37 AM
  • 55,649 POSTS
This sounds like a classic compressor clutch coil failure. When the A/C is not working take a test light and check to see if it getting power. Here is a guide to help you:
and
and this will give you an idea of what you need to do if it is bad:
https://www.2carpros.com/articles/replace-air-conditioner-compressor
Please let us know what happens, we are interested to see what it is.
Cheers, Ken
Jul 11, 2017 at 7:57 AM
TINNOV
Thanks for the information. I will throw a volt meter in the back and next time it cuts out. I will check it.
Jul 12, 2017 at 4:26 AM
  • 55,649 POSTS
Please let us know what you find.
Cheers, Ken
Jul 12, 2017 at 8:39 AM
TINNOV
So I was driving along and heard a sound I hadn't noticed before... It sounded like someone in the distance had honked their horn, then the A/C stopped working for a while, just as described above. I didn't get a chance to pull over and check the power to the compressor clutch coil, but it wasn't much of a stretch to imagine that the compressor clutch tried to (and failed to) engage. I had the clutch and coil replaced and all seems well now.
Thanks!
Jul 19, 2017 at 3:49 AM
  • 55,649 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
Jul 19, 2017 at 4:10 AM
