The A/C was blowing warm air. I added dye and found a leak at the condenser and line from compressor to condenser. Replaced both and the line came with a new pressure switch. Vacuumed and charged the system. Getting cold air now but noticed the clutch isn’t cycling on and off. Clutch disengages if I turn off the A/C. Is this normal? What should I check?
Apr 16, 2022 at 8:06 PM
