transmission will not engage after engine swap
150,000 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
MALHAVOK
Switch the engine from a 1998 4 wheel drive Jimmy into my truck which is listed above both vehicles had a 4.3 V6 . I did this because it had a blown engine. The engine works fine just cannot get the transmission to engage. I have checked all the fluid levels there good, transmission linkage works, properly.The parts we changed. knock sensor oil filter adapter and I believe that is it. I do not know if we need to change the PCM or what we need to change to be honest that is the question why will the thing not engage?
Thanks for your help!
Jun 18, 2017 at 3:11 AM
  • 55,770 POSTS
Lets run the codes to see if there is any problems the computer can see first.
Here is a guide to help you get going.
Please run this test and get back to us so we can continue helping you.
Cheers, Ken
Jun 21, 2017 at 4:21 AM
MALHAVOK
I forgot to mention that we used the torque converter from the Jimmy also. My buddy has been doing most of the work and he said that the one from the Sierra caused engine to stick out about an inch. I can't run codes right now. We've dropped tranny to pull the. I was going to haul them both somewhere and pick someone's brain to get this thing running.
Jun 21, 2017 at 8:30 PM
  • 55,770 POSTS
Please let us know what happens, we are interested to see what it is.
Cheers, Ken
Jun 22, 2017 at 3:29 AM
MALHAVOK
Haven't had the chance to take it in yet. Would you happen to know the difference between the 2 TC? I know that the different splines and impeller angles etc create differebnt pressures I just don't understand why the same transmission would have two different torque converters.
Jun 24, 2017 at 12:14 AM
  • 55,770 POSTS
V8 and V6 torque converters are different due to the power and torque outputs.
Jun 24, 2017 at 3:42 AM
MALHAVOK
THEY ARE BOTH 4.3 V6
Jun 24, 2017 at 4:01 AM
  • 55,770 POSTS
How are the converters different? Can you upload a picture so I can see?
Jun 26, 2017 at 2:12 AM
