Could it be the engine oil feeder system failed? Could be. There's a relay for it-look at the cover similar to the EFI relay.
Okay about the oil light -clear it by remove the EFI fuse for 10secs or better.
I have a 95 I don't even use the 2qts container or the engine oil feeder-I took the relay out. Just be checking the oil thru under the driver seat.
Hope this helps -Good Luck
Sunday, May 27th, 2007 AT 10:18 PM
