Thermostat replacement
Removal Procedure:
1.Remove the air cleaner and duct assembly.
2.Drain the coolant until the coolant level is below the thermostat. Refer to Draining and Filling Cooling System .
3.Remove the crossover exhaust pipe.
4.Remove the radiator hose from the thermostat housing
5.Remove the thermostat housing bolts and clean any sealer from the bolt threads.
6.Remove the thermostat housing and gasket.
7.Remove the thermostat.
8.Clean the mating surfaces.
Installation Procedure:
1.Install the thermostat.
2.Install the thermostat housing and gasket.
3.Install RTV sealer, GM P/N 1052366 or the equivalent, to the thermostat housing bolt threads. .
4.Install he thermostat housing bolts.
Tighten
Tighten the bolts to 25 N.m (18 lb ft).
5.Install the radiator hose to the thermostat housing.
6.Install the crossover exhaust pipe
7.Install the air cleaner and duct assembly.
8.Fill the cooling system. Refer to Draining and Filling Cooling System .
9.Inspect the cooling system for leaks. Repair as necessary.
SPONSORED LINKS
Saturday, December 6th, 2008 AT 10:23 PM
