How to gather and read obd1 trouble codes for eagle cars made between 1988 and 1996. You do not need a code reader to gather these codes but you will need a test light.
Step 1
Start by locating the diagnostic connector under the glove box. The Eagle Summit connector will be in the fuse box.
Step 2
Ground a test light and insert the probe end into the number 1 terminal.
Step 3
Turn the ignition key to the on position and observe the test light. Long blinks represent the first position of the code number while the short blinks represent the second position of the code number. For example; if the light blinks two long times, then blinks four short times the code number is twenty four. Turn the key off and then on again to restart the test.
Step 4
Once the repairs have been made disconnect the negative side of the battery for thirty seconds to clear the codes. If a problem still exists the car must be driven about twenty five miles before the check engine light will come back on.
Code Table
11 - Oxygen sensor
12 - Airflow sensor
13 - Intake air temperature sensor
14 - Throttle position sensor
15 - Idle speed motor position sensor
21 - Coolant temperature sensor
22 - Crank angle sensor
23 - Top dead center sensor (crankshaft position sensor)
24 - Vehicle speed sensor
25 - Barometric pressure sensor
31 - Knock sensor (turbo models)
32 - Faulty MAP sensor
36 - Ignition timing adjustment signal (1.8L, 91-up)
39 - Faulty oxygen sensor
41 - Injector
42 - Fuel pump
43 - EGR (California)
44 - Ignition coil or ignition power transistor unit (cyls. 1 and 4)
52 - Ignition coil (cylinders 2 and 5)
53 - Ignition coil (cylinders 3 and 6)
55 - Idle air control valve
59 - Rear heated oxygen sensor
61 - ECM - transaxle interlink
62 - Warm-up valve position sensor
62 - Variable Induction Control valve position sensor 93-up
71 - Traction Control vacuum valve solenoid.
Eagle Premier 1991-1992 and Vision Cars
11 - Ignition reference circuit
13 - MAP sensor vacuum circuit
14 - MAP sensor electrical circuit
15 - Speed/distance sensor circuit
17 - Engine running too cool
21 - Oxygen sensor circuit
22 - Coolant temperature circuit
23 - Charge temperature circuit
24 - Throttle position sensor circuit
25 - Automatic idle speed control circuit
26 - Peak injector current not reached
26 - Injector circuit
27 - Fuel injection circuit control
32 - EGR system
33 - Air conditioner clutch relay
34 - Speed control solenoid driver circuit
35 - Fan control relay circuit
42 - Automatic shutdown relay control
43 - Ignition coil circuit
51 - Oxygen sensor lean
52 - Oxygen sensor rich
53 - Internal engine controller fault
54 - No camshaft position sensor signal
55 - End of message
63 - EPROM write denied faulty ECM
77 - Speed control power relay
Got Any Questions?
If you have any obd1 code questions, please visit our forum. If you need car repair advice, please ask our community of mechanics is happy to help you and it is always 100% free.
We are creating a full set of car repair guides. Please subscribe to our 2CarPros YouTube channel and check back often for new videos which are uploaded almost every day.
