How to Replace a Serpentine Belt Tensioner
There are many configurations of serpentine belt tensioners, but all follow the same principle which is to keep constant pressure or tension on the engine's serpentine belt. This spring loaded device is mounted to the front of the engine and in most cases is fairly easy to replace.
How Does it Work?
Fitted with an internal spring, a serpentine belt tensioner consists of a main housing, pivot point, a tension spring, a smooth pulley with a roller bearing. These units are non-adjustable and require no maintenance except for replacement.
What Goes Wrong?
In time a serpentine belt tensioner can wear out allowing the serpentine belt to roll off the main drive and accessory pulleys such as the water pump or alternator. Also, the pulley that is attached to the tensioner has a roller bearing which can go bad creating a squealing noise, especially under acceleration, and if the bearing seized up completely it will throw the belt off entirely. A belt tensioner is a normal wear item and should be inspected regularly.
Cost?
Typically replacement parts will cost between $30.00 and $80.00 on Amazon (US) or the parts store and will require the removal of the serpentine belt. Labor time can be between .5 and 2.0 hours at a shop or dealer. If exact times or procedures are needed you can one of ask our experts to supply you with the information (free), or consult an online resource such as AllData DIY (pay), but this guide and video will be sufficient in most cases. Some tensioners feature a replacement pulley separate from the housing and spring assembly which can save money.
Let's Jump In!
Step 1 - You may need to disconnect the battery before you start the job if electrical wiring is involved, and in some cases you will need to drain the cooling system as in the example below. Also, the serpentine belt, heater hoses and alternator have already been removed. Most cars will not have heater hoses running through the tensioner.
serpentine belt tensioner replacement
Step 2 - Locate and remove the belt tensioner mounting bolts, in this case there are two bolts which are 13mm and 15mm, most tensioners will have one to three mounting bolts.
remove bolt from tensioner
Step 3 - Here, our mechanic is removing the tensioner so it can be matched up to the new unit.
remove serpentine belt tensioner
Watch the Video!
Please watch this video of the job being done, then continue down the guide to glean additional helpful information.
Step 4 - The old unit and new tensioner need to match identically to ensure a proper installation. You can also see we are installing a new serpentine belt which is highly recommended when doing the job.
new serpentine belt tensioner
Step 5 - Lower the new part down into the engine bay and onto the engine, line up the mounting bolt holes.
install serpentine belt tensioner
Step 6 - Reinstall the belt tension mounting bolts and tighten to specification which in this case was 23 foot pounds of torque, then continue with the reassemble and you are all set.
install serpentine belt tensioner bolts
Additional Serpentine Belt Tensioner Replacement Videos
Questions?
Our certified technicians are ready to answer serpentine belt tensioner questions for free. We hope you saved money and learned from this guide. We are creating a full set of car repair guides. Please subscribe to our 2CarPros YouTube channel and check back often for new videos which are uploaded regularly.
Article published
