How to Test a Gear Range Sensor - Neutral Safety Switch
The functionality of the neutral safety switch has changed greatly through the automotive development era, what was once a simple switch for the reverse lights and starter safety circuits, this switch has now become a multi-function gear position sensor which provides feedback data to the body and engine computers, all related functions are then carried through the operating system. The neutral safety switch disables the starter operation when the vehicles transmission is not in neutral or park, and are equipped on automatic transmission vehicles only.
 A standard transmission car utilizes and clutch safety switch in place of the neutral safety switch which accomplishes the same objective. When a neutral safety switch fails it can cause the starter or reverse lights not to operate. Other complications can occur if a loose connection exists near the wiring connector, confirm this connection by removing the connector and reconnecting it.
Tools and Supplies
  • Test Light
  • Wiring schematic
  • Neutral safety switch location (component location)
Quick Fixes
    If the starter is not working when the vehicle is in park, try pushing down on the brake pedal and putting the transmission in neutral, this will bypass the park circuit of the switch allowing the starter to operate if the park circuit has failed.
    If a neutral safety switch becomes maladjusted, it can cause the switch to malfunction, confirm the adjustment of the switch.
Let's Jump In!
Identify the neutral safety switch which is located on the left side of the transmission and controls engine starter operation along with reverse lights and gear selection feedback data used by the computer.
Obtain a wiring diagram used to trace wires which enables continuity testing. This switch uses a simple grounding procedure to individual circuits when the switch is activated. Search Google images or an online service manual such as Mitchell1 to obtain such diagram.
wiring diagram neutral safety switch
Using a test light will enable the circuit testing by piercing the wires to confirm a connection through the switch.
test light
Questions?
If you have a car repair question, you can ask the 2CarPros community for help. We hope this guide helped you understand the repair. Please visit our 2CarPros YouTube channel for more helpful repair videos.
Repair Safety Notice: This guide is provided for general informational and educational purposes only. Vehicle repairs can involve risk of injury, property damage, or vehicle damage. Always follow proper safety procedures, use the correct tools, support the vehicle securely when raised, and consult a qualified automotive repair professional if you are unsure about any step.
