Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Other
Engine
Symptoms
Low Power
Z71 Boggs down when giving gas
1996 CHEVROLET
196,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
ROBIN529
MEMBER
when you try to go faster the engine bogs down. it runs great other wise. dont know what else to check .
Apr 7, 2015 at 8:42 PM
Experienced Mechanic
Check fuel pump pressure and check to make sure the catalytic converter isn't plugging.
Apr 7, 2015 at 10:05 PM
ROBIN529
MEMBER
thank you fuel pump pressure is good didnt think of catalytic converters
Apr 7, 2015 at 11:03 PM
Give that a check and also check intake vacuum. You may have a leak at the intake.
Apr 8, 2015 at 3:52 AM
ROBIN529
MEMBER
ok i will do. thank you much
Apr 8, 2015 at 8:13 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
