Can I get the part number on the cam gear thrust bearing that you used your 454 build?
100,000 MILES • 7.4L • V8 • 2WD • AUTOMATIC
FREDDY BRUCE
And did you have to machine the block to use it? Thank you in advance. I have been told you may need to machine the front of the block where the cam thrust bearing goes in order to use one.
Nov 24, 2022 at 6:52 AM
  • 110,248 POSTS
I am going to forward your question to Ryan. He is the one that did the video. If you don't hear back from him within a couple of days, let me know. However, he usually gets back to people quickly.
Nov 24, 2022 at 12:10 PM
FREDDY BRUCE
thank you.
Nov 26, 2022 at 12:00 AM
RYAN L
  • 273 POSTS
Hello Freddy!
Thank you so much for watching the series and for using the site. Our thrust bearing came with our timing set, so it fits the Cloyes timing set perfectly. I believe this is the same one that came in our kit https://www.summitracing.com/parts/clo-9-220/make/chevrolet if you use a Cloyes timing set with this no machining is required.
Thanks for watching!
Nov 28, 2022 at 6:47 AM
FREDDY BRUCE
By the way do you have the part# for the intake gasket set you used? Thank you
Dec 3, 2022 at 5:16 AM
RYAN L
  • 273 POSTS
No problem, it came in this kit https://www.summitracing.com/parts/fel-260-1009
Here is a page with all the links for the build for easy reference. https://www.2carpros.com/articles/big-block-build-sheet
-Ryan
Dec 5, 2022 at 6:29 AM
