Exactly like the question say.. we have had it 3 months and car was working perfect besides a few minor fixes like coolant reservoir, radiator fan, and steering wheel tilt issue. One morning on the way to work the check engine light came on but no affect change in performance. and when I got off work and got outside the car wouldn't start. I hear the fuel pump engage or buzz when I turn the key. I took the valve cover off and the timing on gears appears to be right where it should be, upper 2 anyway, which it's chain driven. Shows no codes on dash or when connected to code reader. Has spark when checked. Has fuel pressure when I press the Schrader valve before the fuel rail, however don't know if it's correct but it is, it does sprays out though. Don't think it's the injectors because I can't see all 4 clogging at once. I'm really not sure? I need ideas and help with one?
Oct 23, 2019 at 1:25 PM
