YD25 engine
290,000 MILES • 2.5L • 4 CYL • TURBO • 2WD • MANUAL
NDIYE STRAW BOTANA
i have a problem with a YD25 engine that does not idle,its for 2010 Nissan Navara. i have changed the camshaft position sensor and crank position sensor.
May 29, 2016 at 7:27 PM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides and iac hole with choke cleaner then check fuel pressure with a gauge. also scan for codes as you mayhave already changed out good parts.
May 29, 2016 at 11:00 PM
RENEE L
  • 1,260 POSTS
Hi Ndiye Straw Botana,
Here is a link to an article that features written step by step instructions and pictures explaining how to do the scan yourself, also I have included a link to our YouTube channel with a how to video on code scanning. Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com. Once you have the codes please get back to us so that we can further assist you. We are always happy to help.
https://youtu.be/YV3TRZwer8k
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
May 31, 2016 at 8:08 AM
