Code c1310 Yaw Speed Sensor location
3,006 MILES
ROBERT OLIVEROS TABON
I have a problem with my ESP flash in my dash. I scanned with my scanner the fault is c1310 yaw speed sensor fault intermittent. I have problem my braking system some times my ABS braking while traveling roundabout and straight. I want to check the yaw sensor but I do not know where it is located.
Nov 9, 2018 at 2:46 AM
  • 55,694 POSTS
The YAW sensor is located near the middle of the car check by the center console between the seats. Please let us know if you need anything else to get the problem fixed. Ken
Nov 10, 2018 at 3:12 AM
