yaw sensor
2011 NISSAN ALTIMA
105,000 MILES • 2.4L • V6 • 2WD • AUTOMATIC
WILLIEDYNAMITE11
  • 37 POSTS
How would the vehicle drive when the yaw sensor is going out or is out?
Jan 31, 2020 at 10:12 AM
The vehicle should not drive any different. The ABS light is most likely on. The yaw sensor only senses the angular velocity so that the ABS system can active if needed. All it does is tell the ABS what this angle is and then the ABS reacts. It is not going to cause the vehicle to drive differently. At worst the ABS will activate when it should not.
Let me know if I miss understood what you were asking. Thanks
Jan 31, 2020 at 10:23 AM
