There is a indicator light that has come on, says PSM.
Oct 25, 2017 at 8:32 AM
✓Experienced Mechanic
That stands for Porsche Stability Management. Make sure there is not a switch to turn the system on and off. If there is not, it will need scanned to determine which sensor is causing an issue.
Oct 25, 2017 at 11:59 AM
This light come on and the system is shut down. It will probably be a wheel speed sensor that is out. Here is a guide that will help you read the codes.
Please let us know what you find. I'm interested to see what it is.
Cheers, Ken
Nov 1, 2017 at 12:52 PM
