Good evening.
It is at the upper hose in front of the engine.
I attached a picture and procedure below.
Remove or Disconnect
1. Negative battery cable.
2. Drain and recover coolant until level is below thermostat.
3. Radiator outlet pipe attaching bolts.
4. Outlet.
5. Thermostat.
Clean
^ Radiator outlet mating surfaces.
Install or Connect
1. Thermostat.
2. Radiator outlet.
3. Attaching bolts.
Tighten
Tighten thermostat housing retaining nuts to 14 N.m (124 lb. in.).
Oct 25, 2018 at 9:34 AM
