What do I do when I had lost almost all transmission fluid and I used half a quart of ATF not CVT to get home?
Dec 6, 2022 at 1:10 AM
✓Experienced Mechanic
The first thing you need to do is drain the entire system and refill it with the correct fluid. I recommend having the transmission flushed rather than a drain and fill because it will get all fluid out and all new in.
Are there any issues at this time? Also, how far was it driven this way?
