Will not go into reverse
200,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
JAYGROVES1
When i shift into reverse it feels like it goes into gear but will not move at all. Sometimes I can hear a gear noise from transmission when in reverse. It could be just me, but does not seem like it. I did not have a problem until i started using my air conditioner more often.
Jun 24, 2016 at 10:33 PM
good morning my name is Roy and I will assist
it sounds like a planetary failure internally especially with the grinding gears.
make sure the fluid level is correct and the filter is not clogged.
Jun 26, 2016 at 1:28 AM
