My engine would not start up?
180,000 MILES • 3.5L
JOY PONTIOUS
car shut off while driving would not start, no codes came up. found the fuse for fuel pump blown changed started and ran after running twenty minutes and turning off now it starts and runs but very rough. what could be the problem?
Sep 27, 2017 at 3:21 AM
SATURNTECH9
  • 30,869 POSTS
This sounds like the crankshaft angle sensor or the fuel pump has gone out, when you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
Sep 27, 2017 at 5:53 AM
JOY PONTIOUS
it was the fuel pump thank you so much this site is great!
Sep 28, 2017 at 12:00 AM
SATURNTECH9
  • 30,869 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
Sep 28, 2017 at 4:10 PM
