Check out the images (below). Let us know if you need anything else.
Images (Click to enlarge)
Dec 2, 2025 at 1:20 AM
KEVINV1645
MEMBER
Awesome! These ATC'S :-(
Dec 2, 2025 at 2:02 AM
✓Experienced Mechanic
Yep, they can give troubles for sure, let me know what the problem was if you can :)
Dec 2, 2025 at 2:07 AM
KEVINV1645
MEMBER
Hi Ken L, The wire diagrams are very helpful, thanks! Looking for info specific to the pcb components, aspirator motor and the rest. Need to troubleshoot what fails. Don't believe its a BCM issue. ATC has no relay. Rabbit hole...I know. If you can help, great, if not, that if fine, also.
Dec 3, 2025 at 12:41 AM
Sure, I will help you, the first thing I would do is a CAN scan to see what codes are stored, please go over this video which should help us retrieve the codes.
