Worn back tire on the inside
2011 NISSAN NAVARA
135,436 MILES • 2.5L • 4WD
KEVIN
Hi my name is Kevin. the back tire on the driver side is worn on the inside it only happen when I had new leaf spring's and new shocks fitted. could you help? yours thankfully, Kevin
Apr 22, 2019 at 7:26 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It is possible when the new spring and shock were installed something was misaligned causing the camber adjustment to be off causing your inside tire wear.If you take your car to a tire shop or repair facility have them check/adjust the camber setting.Here is a tutorial showing tire wear:
https://www.2carpros.com/articles/how-car-tires-work
Hope this helps and thanks for using 2CarPros.
Danny-
Apr 23, 2019 at 3:56 AM
KEVIN
Hi my name is Kevin, I have the vehicle listed above. the back tire on the driver side is worn on the inside it only happen when I had new leaf spring's and new shocks fitted. could you help? yours thankfully, Kevin
Apr 23, 2019 at 6:01 AM (Merged)
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
I believe you've asked this question twice. Here is the answer again:
Danny-
KEVIN
Hi Danny .Kevin here. is there chambers on the back of a Nissan Navara? the leaf spring's can only go on one way is that right? the other side is find. looking forward to hearing from you. thanks, Kevin
