Turn the key and it doesn't crank. Checked battery and it is costed and Cleves battery terminals are good.
Apr 9, 2023 at 11:04 AM
✓Experienced Mechanic
Do the lights go out when you crank it? do you have a security light flashing? If you have neither of these we need to check to see if the starter trigger wire is getting a signal.
This guide will help, also try to crank the engine over while the transmission is in neutral:
