Will not turnover
177,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
THOMAS68
The issue seemed to start when the weather was wet/damp. The van would not want to start right away. Then would seem to be missing until got warmed up. This past weekend we had a lot of rain. Monday it barely started and made it approximately a quarter of a mile then quit. Now will not turn over. Have some spark going to coil pack. No codes are showing either on odometer or diagnostic tool.
Sep 12, 2018 at 8:44 PM
Good morning.
Some spark? can you explain?
I would start with checking the fuel pressure to be sure you have fuel going to the engine.
Then spark test.
Lastly, a compression test to be sure there is nothing wrong internally in the engine.
Sep 12, 2018 at 10:40 PM
