Will not turn right all the way
207,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
JONATHANDINGMAN
My steering wheel only turns right one and a quarter turns and stops compared to turning left two and a half turns as it should. any idea what it is?
Nov 28, 2019 at 12:03 PM
  • 110,248 POSTS
Has there been any front end work done to the vehicle recently? Also, have you checked to make sure there is nothing stopping the wheels from turning? Is there anything bent as far as a drag link, tie rod, and so on?
Nov 28, 2019 at 12:42 PM
JONATHANDINGMAN
Bought the truck like this nothing seems bent or catching.
Nov 28, 2019 at 1:49 PM
  • 110,248 POSTS
If nothing appears damaged, there is a chance that the steering gear was replaced, not centered, and then aligned that way. Does anything appear to be new under the vehicle?
Nov 28, 2019 at 2:27 PM
JAMES HILLSTRAND
I've seen some vehicles too the steering wheel being repaired but not aligned. Lift the front wheels and have someone to watch them as you turn the steering wheels.
Nov 28, 2019 at 3:03 PM
  • 110,248 POSTS
That's a good idea. See if there is anything binding or hitting.
Let us know what you find.
Nov 29, 2019 at 11:49 AM
