had possible short and bad battery. changed battery and i think i have shorted wire or bad pcm. anyone have diagram so i can test wires for short
Nov 24, 2025 at 10:18 PM
KRAKENAUTO
✓Experienced Mechanic
I have attached the wiring diagram for the charging system (the first image, it wouldn't let me delete the others) as a start. Have you checked all fuses? It should have tripped under normal circumstances. Also check power and ground to the battery itself.
Images (Click to enlarge)
Nov 25, 2025 at 1:31 AM
Nice work KRAKENAUTO, So is the engine not cranking over? Here is a video to help you see what it could be,
