You have isolated the problem yourself. It is either going to be in the ignition switch or the wire going to the starter solenoid. I have included in the diagrams below a factory diagnostic troubleshooting guide for the ignition switch. Please go through it and if the ignition switch is okay I can give you instructions on how to do a voltage drop test on the wire to confirm it's the problem if you wish. Either way, please get back to us with what you find out.
Thanks,
Alex
2CarPros
Images (Click to enlarge)
Apr 21, 2019 at 8:55 AM
