Won't turn over pop the clutch?
258,000 MILES • 3.0L • 4 CYL • 2WD • MANUAL
RHAWK007
Switch won't work but I can pop the clutch to start it,I assumed it was the brake light switch
Jan 16, 2026 at 10:18 PM
  • 55,721 POSTS
It sounds like the starter motor is not working, to be sure we need to test the trigger wire for power when the key is in the crank position and the clutch pedal depressed. This is a super good video so we can see what the problem is:
https://www.youtube.com/watch?v=6YRW8fyNudY
I don't want to just start replacing parts until we know what the problem is. Please go over this guide and get back to us so I can help you fix the car.
Jan 17, 2026 at 2:53 AM
RHAWK007
I watched that video earlier ,where is the trigger wire located
Jan 17, 2026 at 5:17 AM
  • 55,721 POSTS
It is the small wire going to the starter motor solenoid. You may need to raise the car up to get to it. If you upload images I can help walk you through it.
Jan 18, 2026 at 1:19 AM
