To better assist you is your model the LS or XR7 and what is the engine size in liter?
Why did you change the starter and relay?
So if I understand you correctly..... When you turn the key to the start position... You get nothing, no engine turning over, no sound or movement other than your lights dimming?
If this is so, are you sure your battery is fully charged?
Next, please be careful when you do this, make sure the car is in park, emergency brake on. Take jumper cables and go right from the battery to the positive connection on the starter and see if the starter spins.....
SPONSORED LINKS
helpful?Yes
Tuesday, September 22nd, 2020 AT 11:12 AM
(Merged)
