Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Jeep
Cherokee
Engine
Symptoms
Not Cranking Over
Will not turn over
1998 JEEP CHEROKEE
160,000 MILES • 6 CYL • 4WD • AUTOMATIC
LASUNSHINE
MEMBER
put key in ignition, dashboard lights come on sounds like it wants to turn over but it's like its not getting enough gas.
Jul 2, 2019 at 12:32 AM
Experienced Mechanic
Good morning,
Does the starter work and crank the engine?
Can you hear the fuel pump run with the key on?
Does the tachometer move up a little while cranking?
As much information is appreciated so I can help you.
Jul 2, 2019 at 12:52 AM
LASUNSHINE
MEMBER
Yes, when I put key in ignition everything sounds like it should, it’s just not engaging.
Jul 2, 2019 at 1:00 AM
The starter is not engaging?
Jul 2, 2019 at 1:03 AM
LASUNSHINE
MEMBER
I think, or it’s not getting fuel.
Jul 2, 2019 at 1:06 AM
We are not getting anywhere.
Can you upload a video of when you try to start it so I can see and hear it?
Jul 2, 2019 at 1:08 AM
LASUNSHINE
MEMBER
Yes I can, but I’m at work now.
Can I send it later? When I leave work at 4:00 pm.
Jul 2, 2019 at 1:10 AM
No problem.
We will be here for you.
Jul 2, 2019 at 1:22 AM
LASUNSHINE
MEMBER
Jul 2, 2019 at 1:23 AM
You are welcome.
Always glad to help.
Jul 2, 2019 at 1:26 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
