Will not turn over
150,000 MILES • 3.7L • V6 • 2WD • AUTOMATIC
KEVIN SUTTON
Have a new battery and crank shaft and just replace the fuel pump. It ran the for two days and now it will not start still, but will start if I pour gas into the carburetor.
Dec 25, 2017 at 1:31 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Can you hear the fuel pump run for a few seconds after you first turn the key to run, before you turn the key to start?
Also, do the check engine light and security light both come on for bulb check then go out after fifteen seconds or so, or do either stay on or flash?
If the security key flashes or is on, try a spare key or clean that key where the pellet is and try again.
If the fuel pump does not run, check the fuel pump relay and PCM fuses and if okay, try to swap that fuel pump relay with something not important like a horn relay, etc., and try again if the fuel pump runs.
If there is a check engine light staying on or flashing, then there is a code set so you should have them codes retrieved.
Dec 26, 2017 at 6:36 AM
