Will not stay running?
148,000 MILES • V6 • AUTOMATIC
MYLUCKYCHARM2128
I replaced the starter alternator and battery, and I was driving it fine then while driving it shut off in the middle of the road. So, then I got it home by towing it. And found the starter positive wire was touching the catalytic coveter and melted it a little. So, I covered the wires and made sure they weren’t touching, and it still needed a jump start and when I take the jump starter off it shuts off.
And then there is a wire the it has a plug that plugs into the whirring under the battery, and it is a thin wire that is cut and has voltage that has been like that since I got it.
Pearl
Sep 11, 2024 at 3:08 AM
  • 110,248 POSTS
If the battery shorted to the converter, there is a chance more damage was done than you think. Have you inspected all fuses in the under-hood fuse box?
At this point, does the starter do anything when you try starting it or does it need jump started each try?
Sep 11, 2024 at 11:55 AM
