wont stay running/cuts off while running
180,000 MILES • V8 • 4WD • AUTOMATIC
CAZZ47
I have replaced battery, alternator, spark plugs, all fluids, and she revs up on her own then cuts off if I'm at a stop light, after driving for a while and I turn it off it takes 20-30min before she starts up. A retired mechanic told me my engine could be flooding but he wasn't sure. If you could help me out with an answer id surely appreciate it thanks.
Aug 10, 2014 at 10:27 AM
  • 110,251 POSTS
Has the check engine light come on? Have you checked fuel pump pressure when the vehicle doesn't start? Have you checked the idle air control valve? Have you checked for vacuum leaks?
Aug 10, 2014 at 12:31 PM
CAZZ47
I have checked all the above no problems, I have not checked the fuel pump pressure.
Aug 10, 2014 at 12:49 PM
  • 110,251 POSTS
Check the pressure to make sure it is within the manufacturer's specs. Also, if it is flooding (Fuel Mixture too rich) you should see black smoke from the exhaust. Is there any smoke?
Aug 11, 2014 at 12:06 PM
CAZZ47
There is no black smoke, I don't know what the manufacturing specs are for the pump pressure
Aug 11, 2014 at 1:37 PM
  • 110,251 POSTS
With the engine at an idle, it should be between 44 psi and 54 psi. Do you need directions as to how it is checked?
Aug 12, 2014 at 9:10 AM
CAZZ47
Yes please if you wouldn't mind
Aug 12, 2014 at 9:13 AM
  • 110,251 POSTS
