Will not stay running
200,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
JUSTIN CASE GREEN
Will start and run for about five seconds then shuts off, but then will start up the same way and run.
Can this be a fuse issue or something else, a few fuses have been stolen.
Mar 10, 2019 at 6:32 AM
  • 55,684 POSTS
I would start by replacing the fuses. can I ask if the security light is flashing when you try to start the engine? if so here is a guide to help reset the system:
https://www.2carpros.com/articles/how-to-reset-a-security-system
Mar 14, 2019 at 5:42 AM
JUSTIN CASE GREEN
It was the air filter being loose, but I will be getting the fuses replaced on Monday.
Mar 17, 2019 at 2:45 AM
  • 55,684 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Mar 17, 2019 at 8:55 AM
