Won't stay running?
155,000 MILES
JAYMELYLES48
The vehicle will start but only run for like 5 seconds then die
Mar 18, 2026 at 12:47 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Identify the engine and obtain current diagnostic codes before deciding which component to replace. Have the starting-and-stalling behavior assessed and the proposed fuel-delivery check performed using the correct equipment and vehicle specifications. Return with the codes and measured results so the next step can be based on evidence. The thread does not establish a failed fuel pump or another specific cause.
Guidance references and applicability
2CarPros: Original discussion 1712372 https://2carpros.com/questions/wont-stay-running-18957484 Source for the owner's reported history and outcome. Contributor suggestions are not independently confirmed diagnoses. No attachment content was verified.
Read the replies · Discussion summary and reported outcome
CANNON1349
  • 861 POSTS
Hello, if you keep your foot on the gas, does it stay running?
William
Mar 18, 2026 at 11:23 PM
JAYMELYLES48
Mar 28, 2026 at 7:56 AM
CANNON1349
  • 861 POSTS
Do you have access to a scanner? They are around $20 on Amazon and should be the first step in tackling the issue. It will help inform of any trouble codes in the memory. Next step is that we need to check that fuel is being delivered to the rail and is pressurized. Please let us know.
William
Mar 29, 2026 at 12:21 PM
Discussion summary
Won't stay running?
The owner reported that the vehicle started but stalled after about five seconds. When asked whether holding the accelerator kept it running, the owner answered no. The contributor requested scan results and fuel-delivery checks.
Reported outcome: No diagnostic results or successful repair were reported.
Engine and other vehicle details were incomplete. No fuel-pressure reading, scan result or additional symptom description was supplied.
Read the original discussion
