The vehicle will start but only run for like 5 seconds then die
Mar 18, 2026 at 12:47 AM
CANNON1349
✓Experienced Mechanic
Hello, if you keep your foot on the gas, does it stay running?
William
Mar 18, 2026 at 11:23 PM
JAYMELYLES48
MEMBER
Mar 28, 2026 at 7:56 AM
CANNON1349
Do you have access to a scanner? They are around $20 on Amazon and should be the first step in tackling the issue. It will help inform of any trouble codes in the memory. Next step is that we need to check that fuel is being delivered to the rail and is pressurized. Please let us know.
William
Mar 29, 2026 at 12:21 PM
