Will not stay charged
200,000 MILES • AUTOMATIC
ATHOMPSON
  • 6 POSTS
I changed alternator three times, replaced battery, tensioner, and belt. Drive for a little while until battery ran down. Please help!
Feb 25, 2019 at 4:26 PM
You need to test the voltage at the battery to see if the alternator is working.
Apr 19, 2021 at 3:46 AM
ATHOMPSON
  • 6 POSTS
Yes alternator is working.
Okay, what is the voltage at the battery with the engine is running?
ATHOMPSON
  • 6 POSTS
Battery light indicate in middle when it's crank first as you driving battery meter goes down.
Got it.
Again, what is the voltage at the battery with the engine running?
ATHOMPSON
  • 6 POSTS
14 volts.
Okay, that is the correct voltage.
You say that the voltage drops while it is running?
What kind or brand alternators are you using?
ATHOMPSON
  • 6 POSTS
It begins to drop after five to ten minutes while driving, not sure what kind nor brand. However, I can find out.
Please do. It sounds like the alternator.
ATHOMPSON
  • 6 POSTS
Okay, but I have replaced it twice and the alternator I have now was tested at the place of purchase.
Okay, then you need to check the connectors on the alternator to be sure they are clean and tight. There may be corrosion in the connectors.
