On a rainy day my windshield wiper fuse went out, I turned off my truck to replace fuse, when I went to start it nothing happened....got power, just nothing happens when ignition is in 5 (start) position. I had a broken clamp on the transmission control tube on the gear shift that I then replaced, thinking it wasn't getting into park...didn't fix problem. I've changed the ignition, the pcm relay, the starter relay, I've taken the cables off the battery for 10min to reset computer, and nothing still. It does have the Securilock passive anti-theft system. Any help??
Jan 21, 2015 at 12:14 PM
