Will not start, backfires
60,000 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
BILL WILSON4
I had a misfire code truck would not start just cranks,replaced Cap and rotor, wire's and plugs 1 year ago,l just replaced the coil and ICM. Will not start, backfires, is trying to start.
Dec 23, 2019 at 5:55 AM
Good afternoon,
I would check the compression first to be sure the timing chain has not jumped time. Backfires are when spark happens at the wrong moment.
https://www.2carpros.com/articles/engine-backfires-while-running
Dec 23, 2019 at 6:46 AM
