Will not start without battery jump
158,000 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
LYNDA LANE RUWWE
It has been running good. Vehicle wouldn't start today. I had to jump battery. I have put in new alternator (it is good), new battery (checked it is good), new radiator, new fuel pump, new power steering pump. I know i need a new serpentine belt. Could that disrupt alternator from charging battery? I need ideas. Thanks.
Jan 17, 2019 at 4:30 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Yes, that is a possibility. If you say that the battery and alternator have tested good it is possible that the serpentine belt and or the tension-er are not holding the belt in place with proper force/tension.That will cause the problem.This will keep the engine while running from having the alternator keep the battery charging. Here are a few tutorials to view showing what is involved:
https://www.2carpros.com/articles/how-a-serpentine-belt-works
https://www.2carpros.com/articles/how-a-serpentine-belt-tensioner-works
https://www.2carpros.com/articles/replace-serpentine-belt
https://www.2carpros.com/articles/serpentine-belt-tensioner-replacement
I've attached a picture of the belt routing diagram below.Hope this helps and thanks for using 2CarPros.
Danny-
Jan 17, 2019 at 6:45 PM
LYNDA LANE RUWWE
I changed the serpentine belt and still had the problem. I started checking the wire connections and located the problem with alternator wire in clamp was loose and secured it in. Starts everytime now and battery stays charged. Thank you
Feb 4, 2019 at 2:39 PM
DANNY L
  • 5,648 POSTS
You are welcome!
Thanks for using 2CarPros. Hope you will use us again if a problem arises.
Danny-
Feb 5, 2019 at 10:19 AM
