Wont start unless sits for 30 minutes
COASTALDC
  • 1981 DODGE RAM
  • V8
  • 4WD
  • 43,000 MILES
Truck starts, runs fine for a while, sonetimes will stall if I put it into reverse, if I shut it off or it stalls it will not re-start for 30minutes or so, like it has to cool down. I replaced plugs and coil
Saturday, December 28th, 2013 AT 12:41 PM
HMAC300
  • 48,601 POSTS
Check the fuel pressure with a gauge it may be getting hot and not pumping right. Autoparts rent them also check your resistance for the crank sensor as these go bad you'll have to check against new as we have no specs on these.
Saturday, December 28th, 2013 AT 1:51 PM
