Will not start suddenly
200,000 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
AMYJB
  • 5 POSTS
All of a sudden the car wouldn't start. have full battery power but car won't even try to turn over. Under the hood in fuse box it clicks when you try to start it. Tried to bypass relay to start car with starter motor and it tries to turn over but won't. Please help!!
Oct 29, 2020 at 6:57 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
You might just be having an issue with the starter motor-solenoid assembly altogether. Here are a few tutorials on having starter issues and replacement:
https://www.2carpros.com/articles/how-a-starter-and-solenoid-works
After removal most auto parts stores will test for free.
I've attached picture replacement pictures below for your vehicle. Hope this helps and thanks for using 2CarPros.
Oct 29, 2020 at 7:57 AM
AMYJB
  • 5 POSTS
Hi, so we put in a brand new starter and it still won't even try to turn over.. Battery is good and so is the starter relay... You can hear a click when you try to start it... What could the problem be??
Nov 14, 2020 at 5:04 AM
94 TRANSAM
  • 680 POSTS
It sounds like your motor might be seized. The click you hear is probably the starter engaging the flywheel but the motor wont turn over. Put a socket on the crank and try and turn it over by hand. If it wont turn the motor is seized.
If the timing chain broke or the tension-er malfunctioned the valves may have got out of time and hit the pistons.
Nov 15, 2020 at 1:29 PM
DANNY L
  • 5,648 POSTS
Hello again.
Have you had a chance to have the starter tested? Sometimes even new components fail. Keep us updated as we're curious to know the outcome. Let us know if you have any further questions on this issue as we're here to help. Thanks again for using 2CarPros.
Danny-
Nov 26, 2020 at 1:32 AM
AMYJB
  • 5 POSTS
Well, I ended up taking it to a shop. I turned out to be a broken plastic piece inside the ignition that broke a wire too.
Nov 26, 2020 at 1:37 AM
DANNY L
  • 5,648 POSTS
Hello again.
Glad to hear the problem was resolved. Thanks again for using 2CarPros and hope you will use our site again in the future. Happy Thanksgiving.
Danny-
Nov 26, 2020 at 1:48 AM
