Will not start, it has error on odometer screen, replaced starter?
150,000 MILES • 3.4L • 6 CYL • 4WD • AUTOMATIC
MBORICH1006
Jumped relay #57 and motor turned over and started for only a few seconds.
Jul 31, 2022 at 12:14 AM
  • 55,859 POSTS
If it has an error message on the odometer screen it means the instrument cluster might be bad and not allowing the engine to start. To be sure we can do a CAN scan which is easy, you can get a CAN scanner from Amazon for about $30.00.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Here is a scanner link:
https://amzn.to/3o41KcZ
This guide can help you as well:
https://www.2carpros.com/articles/car-not-running-advanced
Here is how to change the cluster out in the diagrams below. Check out the diagrams (below). Please let us know what happens.
Aug 1, 2022 at 1:53 AM
MBORICH1006
I have a obd11 reader but will not connect says “no comm”.
Aug 1, 2022 at 3:08 AM
  • 55,859 POSTS
Does the scanner work on other vehicles? lets make sure fuse # FRT AUX 20 amp is good in the under hood fuse panel. This is what powers the scanner on. Also see if the fuse has power.
Aug 3, 2022 at 2:40 AM
