Sometimes the instrument panel or radio flicker or go out when I'm driving. Research says it is likely a ground cable issue. I have replaced the alternator in the last few months. I went out to crank this morning and the lights came on, the fob worked and it started to crank but immediately shut off. The lights quit working and the fob wouldn't work. I thought it might be the battery but everything was fine for a few seconds and I just had it charged when I replaced the alternator. AutoZone tested it and said it was fine when they charged it. I'm thinking it is the ground battery cable because it is kinda worn. Am I on the right track?
Oct 24, 2019 at 7:25 PM
