Will no start, no engine codes
250,000 MILES
KRISTEN DUNCAN HOBBS
I have the car listed above that turns but will not start. There is no engine light. I cannot seem to get any codes. It has spark, it has fuel. Will not start with starter fluid. Help!
Oct 13, 2018 at 4:56 AM
Good afternoon.
Did you check for spark at the spark plug wire?
If it does not start with starter fluid, it either has no spark or possible timing chain.
The next step would be to do a compression test to verify the valve timing is correct.
Oct 13, 2018 at 6:36 AM
Thanks, my husband was thinking it might have jumped a tooth or two. I guess that will be the next check. Thanks
Oct 13, 2018 at 9:16 AM
Sounds like a plan.
Keep us updated.
Oct 13, 2018 at 9:19 AM
