Will not start in cold weather
168,000 MILES • 4WD • AUTOMATIC
ALIBET15
My car will not start in the cold after sitting overnight. It’s fine once jumped and I drive for a bit. I already installed a new alternator, battery, and cleaned the battery terminals, there is no corrosion. Nothing seems to fix this issue. Anything about freezing it will start fine.
Dec 2, 2019 at 4:10 AM
  • 110,248 POSTS
When you say it won't start, do you mean it cranks and won't start or it does nothing at all?
Dec 2, 2019 at 10:45 AM
ALIBET15
It cranks. It sounds like it’s trying to turn over but just can’t without a jump.
Dec 3, 2019 at 4:55 AM
  • 110,248 POSTS
Make sure the ground between the battery and engine block is tight. You mentioned the battery is good, but check the other end. Also, does it start right away with a jump or is still a delayed start? When if first starts, is it smooth? Is there any smoke from the exhaust that may indicate a fuel related issue?
Dec 3, 2019 at 11:07 AM
