no electrical
200,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
CGIB
I just recently purchased this truck (Triton). I was driving to work and the oil light came on and truck shut off. i pulled over and noticed that the oil was fine tried to restart truck and nothing. it has a good battery, but the truck was having a hard time starting since i bought it. it acted as if the starter was week. i pulled it to work and a co worker tried to turn the motor with a ratchet and said it wouldn't turn and it might be locked up. any ideas? because i can't seem to think it could be locked up.
Aug 21, 2019 at 1:31 PM
If the motor does not turn easily with the plugs removed, then there is internal damage in the motor and most likely the motor will have to be replaced.
https://www.2carpros.com/articles/how-to-change-spark-plugs
If it does turn easily, I would start with basics such as testing the battery to be sure it has enough power to turn the motor.
Jan 20, 2021 at 2:13 AM
