wont start getting fuel and fire
91,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
CHEEP RIDE 88
2.5 wont start after running the night before. it is getting fuel and has fire on plugs The timing is gear to gear but i have loosened and turning distributor while trying to start i have put gas down the intake truck still will not start. Any help would be appreciated.
Dec 18, 2014 at 3:31 AM
HMAC300
  • 48,601 POSTS
scan for cods first then check for spark should be blue at plugs. It may e dist as these had reluctor problems in dist which would crack and not allow spark. Also check coil wires and coil.
Dec 18, 2014 at 4:09 AM
